Topic: is vorbis still better (Read 12778 times) previous topic - next topic
I have not been up to date on formats as I have been gone overseas and want to know if aotuv vorbis is still better than aac as of 2013. I have little time to search through the forums and use a rockboxed 5.5G ipod and have many cd's that have to be converted.
... wouldn't say better but I still prefer Vorbis AoTuv for my Rockboxed Sansas (E280, Fuze, Clip+).
Quality is transparent to my ears (--quality 5,47) and the devices have good battery life due to the highly optimized decoder.
Greetings, ...
At higher bitrates, say 128kbps average and above, there's probably little difference.
If you're aiming at 64 to 96 kbps, various recent public listening tests show Vorbis AoTuV is probably a little better than Nero LC-AAC (or HE-AAC at 64k) but not quite as good as Apple Quicktime/iTunes/QAAC AAC encoder. The FhG AAC encoder supplied with WinAmp was beaten by QAAC CVBR mode in the 2011 96 kbps AAC test.
The new Opus codec is also statistically superior to all these at 64 kbps (and the 1.1 beta build improves its weakest samples in that test). At 96 kbps, it's much more marginal in some single-listener tests.
I meant to add that it's all dependent on the sample and the listener in question, so 'your mileage may vary', but the above are summaries of multi-user test results.
