Topic: Daphile - Audiophile Music Server & Player OS (Read 92628 times) previous topic - next topic
Reply #75
Hi All.
I've been using Daphile for some time and it's a very good software for my audio system.
I've got one problem, when I fix usb drive and try to copy 100GB files to an internal drive with daphile it take over 30hours.
I have android tablet and copy files with total commander connected via lan with daphile.
Do you know any solutions to copy files faster using tablet?
Maybe SSh client but how to connect with Daphile via ssh?
Sorry for my english
Adam
Reply #76
New release on June 28th
CHANGES:
  • DRM/KMS graphics drivers enabled. Could help on HDMI audio.
  • Firewire support for Mytek DAC fixed (DoP does not work)
  • DSDIFF scanning fixes.
  • ALSA buffer time and period count defaults changed
  • Kernel upgrade to the latest stable version 3.15.2
  • Some package updates, other minor changes and bug fixes
Update via your Daphile web UI or download from www.daphile.com.
Any feedback is warmly welcomed!
Reply #77
Hi All.
Adam
The problem is that internal drive and USB drive are provided as different shares by Daphile. I think the copying happens in this case so that everything goes via your tablet and that (wireless connection) slows down the copying. You could try to do the copying using another wired connected PC. Unfortunately there isn't currently any other easy solution. If you have some Linux experience you could also boot the PC with another Linux Live USB and do the copying "locally" (the right directory for music on DaphileData partition is /user/music).
Kimmo
Reply #78
New release available!
CHANGES on July 4th 2014:
  • Fix for the previous version web UI problem with iOS browsers (long link names were not truncated properly in Audio Player view).
CHANGES on July 3rd 2014:
  • Work-around fix for "ath9k_htc" kernel driver regression (eg. TP-Link TL-WN722N wifi adapter).
  • Improved current track format info in web UI
  • Kernel upgrade to the latest stable version 3.15.3
  • Other minor changes
Reply #79
CHANGES on July 21st 2014:
  • DRM/KMS graphics drivers are now disabled by default. The enabling must be confirmed after "Save & Restart" in order to verify that system operates properly. It's recommended that you enable them only if you need them for HDMI audio or they solve some other problem.
  • Web UI Audio Player view improvements (not supported in touch devices), eg. resize playlist panel and drag & drop reordering of playlist.
  • Kernel upgrade to the latest stable version 3.15.6
  • ALSA buffer time (320ms->100ms) and period count (6->3) defaults changed again for better generic compatibility
Reply #80
CHANGES on August 10th 2014:
  • Pre-emphasis removal option for the CD ripping
  • Kernel upgrade to the version 3.15.9 and some application package updates
  • Other minor changes and bug fixes
Reply #81
New version available!
CHANGES on the September 16th 2014 version:
  • Player control application on local UI (optional)
  • "File manager" tool in web interface
  • Kernel upgrade to the latest stable version 3.16.2
  • Power saving improvements (eg. dynamic CPU frequency option)
  • Other minor changes (eg. RAM Disk)
  • Bug fixes
Reply #82
  • Bug fixes
Previous release (Sep 16th 2014) had a bug related to CIFS mounting when a username is used. It is now fixed and the new version is available.
