Topic: Daphile - Audiophile Music Server & Player OS (Read 86375 times) previous topic - next topic
Reply #50
Update available!
CHANGES on November 28th 2013:
  • Linux kernel upgrade from 3.8 to 3.12 series (improved audio device support)
  • Bug fixes and minor improvements mostly for CD ripping and networking
Update via your Daphile web UI or download from www.daphile.com.
Any feedback is warmly welcomed!
Reply #51
Update available!
CHANGES on December 18th 2013
  • Some package updates (Perl, LMS, kernel, etc...)
  • Bug fixes (incl. Mytek DAC driver problem with previous version)
Reply #52
Update available!
CHANGES on December 22nd 2013:
  • IPv4LL used as backup for direct PC to PC connections
  • Volume control bug of the routerless setup fixed
  • WMA playback fixed for WMA radio streams
  • Boot graphics mode changed to 800x600x16bit to improve compatibility
Reply #53
Thank you for your great work. Keeps getting better with every release.
NH
Reply #54
Some of the reasons I like this:
Serves only music, no pictures, no movies, just the music
Fast scanning of large collection of FLAC files
Regular updates.
NH
Reply #55
New release on January 30th 2014
Bug fixes:
  • CIFS "sec=ntlsssp" case should finally work
  • Some audio device initialization failure cases
  • Media server start-up failure case
  • Occasional disappearance of network drives
Other changes:
  • Power down monitor 1min after network connection
  • File system clean up – smaller ISO files
Read more about recent changes from the Daphile web page.
Reply #56
Not sure if this was asked, but are you using the Logitech or community build of LMS.
Keep up the great work
Reply #57
Daphile is using Logitech's nightly builds. It's a bit cut down (eg. unnecessary perl libs removed, etc...) and slightly patched (really minor mods) version. The CPAN Audioscan is patched for DSD support.
Reply #58
Reply #59
kipeta,
Thank you for bringing us such a clever system, I have been using/testing various headless computer players 5 years, source hardware changed from internal RME card to HiFace EVO via USB, I have to admit that this is one of the best sounded OS (Windows & Linux, cannot comment on Mac as I am not Mac user) and most importantly the system just make sense, single purpose music player and server with easy setup and very stable, did I mention about it sound excellent? I urge everyone looking for the best sound OS should try Daphile, the sound play through Daphile just clean and fast, you don´t have to worry about DSP setting, up sampling because you don´t need it, it just sound natural.
For reference, I store my Hi-res file in NAS, CD rip in single FLAC with cue sheet store in external USB portable HDD. IBM Thinkcentre as player w/SSD HD and USB3 card, Hi-Face EVO + clock convert to SPDIF feed into Esoteric AI-10 digital amp drive a pair of Maggie 1.7.
Keep up the good work!
Reply #60
So what do you think makes Daphile sound good, and what are you comparing against?
Any special reason to prefer relying on a cue sheet? Doesn't that restrict your choice of software quite a bit?
Reply #61
julf,
From win xp to win 7, foobar with or without up sampling, cplay, rplay, JRM, Media Monkey, Linux ubuntu studio, Audiophile Linux, Gentoo and other distros I couldn´t remember the name, players mainly deadbeef, Audacious, JRM Linux etc.
For archive purpose, I just store a single flac file with cue sheet due to personal preference and cplay only take cue sheet (it was the best sound back then).
Hope this help.
Reply #62
Unless backed by results from a properly conducted double-blind tests, you comparisons are without merit and unwelcome. This is in our terms of service (#8) which you agreed to follow upon registering here.
Reply #63
Hope this help.
Thanks, but not really. Until you provide a description of your test setup along with listening test result logs, it is all adecnotal and subjective - not very useful.
Reply #64
Hope this help.
guys, enjoying music is subjective, I am just trying to share the experience on what I found and I am not saying it is THE best sound OS, and I have no connection with Daphile. It is up to you if you want to try it and you do not need to pay a penny at least for now. By the way, although I believed in 1 and 0 are identical push out from all computers, the user interface and the way how it setup are very much personal e.g. I don´t need to setup vnc/ssh for remote access nor I need to compile custom driver etc, it just make it a step forward compare to my previous experience.
Reply #65
You made a claim that Daphile was better than other OSes for sound. You agreed to a set of TOS when you signed up.
Daphile is not a new OS, it's just stuff sat on top of an existing OS.
Just because you prefer a particular UI does not make it sound better.
Reply #66
New release on February 14th 2014
CHANGES:
  • Kernel version reverted to 3.12.5-rt7 (some HW platforms have boot problem with 3.12 RT patches rt9-rt15)
  • More improvements to audio device initialization
  • Stability fixes for some HW (disable C states > 1)
  • Minor modifications and fixes to web UI (incl. battery indicator)
Reply #67
The CD ripping metadata fetch bug is now fixed. Update via your Daphile web UI or download from www.daphile.com.
Reply #68
julf,
If someone tries so much players and hear them all to sound different there must be indeed some problem but i doubt it is some technological thing.
Reply #69
New release on February 26th 2014
More bug fixes. Hopefully the audio device initialization problems are now fixed (couple of previous releases actually got worse on some setups).
Reply #70
New version available!
CHANGES on March 26th 2014:
  • Faster kexec reboot disabled by default. It does not fully initialize the hardware and this is known to cause some very strange problems.
  • Drive partition table erase tool in initial settings at console (USB-boot)
  • Configurable sample rate change and DoP-PCM mode switch delay parameters for Squeezelite player
  • Credits at Info tab to show license information of included packages
  • Some new configurable options for CD ripping
  • Bug fixes and other minor changes
Reply #71
CHANGES on March 31th 2014:
  • Linux kernel series 3.12 with realtime patch is still having some issues and that's why the kernel is reverted to latest stable RT patched version in the 3.10 series (please contact if this causes problems on your setup).
  • Some other minor bug fixes and changes
Reply #72
CHANGES on April 17th 2014:
  • Squeezelite promoted as the default player (SqueezePlay still available)
  • PCM resampling configuration for Squeezelite
  • Configuration options for ALSA buffer time and period count parameters
  • Package updates, eg. security update for openssl
  • Other minor changes and bug fixes
Reply #73
CHANGES on the May 14th 2014 version:
  • RT-kernel upgraded to 3.12.19-rt30. RT 3.12 series reached stable status. KNOWN ISSUE: Some AMD multicore CPUs don't boot without C1E disabled in the BIOS settings (same problem with RT 3.10 series).
  • Backport patch for USB audio driver: Improve buffer size computations for USB PCM audio (no more nrpacks kernel driver parameter).
  • Option to initialize a new empty data drive in Settings -> Storage.
  • DFF ID3 tag scanning fixed. "Clear library and rescan everything" required.
Reply #74
CHANGES on the May 22nd 2014 version:
  • Kernel upgrade to the latest stable version 3.14.4. CONFIG_PREEMPT_RT patch dropped. Improved stability and compatibility.
  • Experimental support for the DICE based Firewire DACs, eg. Mytek Digital Stereo192-DSD DAC and Weiss INT202/203/DAC202 (none tested).
  • Suspend functionality
  • Power button configuration possibility
  • Some other minor changes and bug fixes
Any feedback is warmly welcomed! I would be especially interested to hear how do the DICE based Firewire DACs work.
