Topic: How to sort albums by release date? (Read 1834 times) previous topic - next topic
  • brx
Is there any way of sorting albums by release date?
I solved this problem by adding a letter next to year, for example: 2013a, 2013b...
and it sorts just fine, but it looks bad when I want to see albums by year...
I want to keep YYYY format of date tag and I want to get it sort correctly.
Any opinions?
Thanks,
Brx
  • Last Edit: 28 July, 2013, 01:53:19 PM by brx
  • Propheticus
In the album list add a view using %<date>%. Personally I use %<date>%|[%album artist% - ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%  when sorting by release date.
  • db1989
  • Global Moderator
Sorting albums by release date where? Although the answer is much the same for Default UI as Propheticus has already provided for the Album List.
The now-abandonware but still popular Columns UI allows separate displaying and sorting strings.
  • brx
I'm using Columns UI and I think a solved the problem.
I put --> %date%  - %album artist% - %discnumber% - %album% - %tracknumber% - %title% <--
in the field of the option: "Sort incoming files by"...
The only thing that annoys me is that, when there are albums of the same year, instead of adding a letter
to a date tag, I'm using now disk number, so for example, if there were 3 albums of the same artist that were released in 2013,
I tagged first album with disk number/total discs --> 1/3, second, 2/3, and the third 3/3 <--
and everything is OK...
Maybe it is not the best solution, but it works... If you know better solution, please let me know...
Thanks for answers!
Brx
  • Last Edit: 28 July, 2013, 04:26:44 PM by brx
  • Propheticus
reverse the album and the disc number, so it's sorted by album first and then by disc number. The sorting string is read and applied left-to-right.
  • BenB
You could always add the month (and day) to the date so that instead of just YYYY, you would have YYYY-MM or YYYY-MM-DD to sort by.
  • Last Edit: 28 July, 2013, 05:26:16 PM by BenB
  • brx
Great tip, but if I do that, there is another problem...
For example:
Date
2011
2012
2013
2013-05-05  <-- I don't want this in column, because sometimes, I want to see which albums are from 2013 and just select that year, not a particular date ...
Is there a way to hide month and day, so there would be only YYYY format in date filter?
Thanks,
Brx
  • marc2003
$year(%date%)
  • brx
$year(%date%)
Great, that's it!
Thanks guys!
Brx
