Topic: Strange linker error (Read 3359 times) previous topic - next topic
  • retierney
Hello,
I am getting the following link error:
initquit.obj : error LNK2005: ___@@_PchSym_@00@UfhvihUylyUwlxfnvmghUerhfzoLhgfwrlLCABAUullyziCAAAUhwpRCABBRADRBBUullyziCAAAUullPko
zborhgPhligUivovzhvUullPkozborhgPhligOlyq@ already defined in foo_playlist_sort.obj
I specified 'Create' for the Precompiled Header option, and
I specified 'Multithreaded DLL (/MD) for the Runtime Library option.
My additional libraries include shared.lib, pfc.lib, foobar2000_SDK.lib and foobar2000_component_client.lib
Thank you very much...
  • retierney
I found a solution.
I rebuilt the project from scratch and this time I set the compiler option Precompiled Header to "Not Using Precompiled Headers." I don't know if this is the correct thing to do, but my project now compiles and links.
  • foosion
  • Moderator
I'm glad you got the problem solved so easily. Precompiled headers can speed up the (re-)compilation of projects which use many and large include files. It is not necessary to use precompiled headers to create a foobar2000 component.
http://foosion.foobar2000.org/ - my components for foobar2000
