Topic: Unwanted tags and track without total tracks (Read 2863 times) previous topic - next topic
  • b0nk
These are the arguments I'm using for lame 3.99.5 in fb2k for a V0 mp3
--ta "%artist%" --tt "%title%" --tl "%album%" --tn "%tracknumber%" --tg "%genre%" --ty "%date%" -h --id3v2-only --noreplaygain -V 0 - %d
fb2k console output:
Command line: "D:\path\to\lame\lame.exe" --ta "Simbiose" --tt "Buried Alive" --tl "Economical Terrorism" --tn "2" --tg "Crust Punk" --ty "2012" -h --id3v2-only --noreplaygain -V 0 - "Simbiose-02-Buried Alive.mp3"
How do I avoid these tags to show up? ENCODERSETTINGS and LENGTH
I also couldn't find how to only add the track without the total tracks.
Thank you for the help.
  • db1989
  • Global Moderator
You probably should not add tagging switches to LAME because foobar2000 will do the tagging for you anyway. I bet LAME is writing some tags, and then foobar2000 is rewriting most of them
Well, guess what! LAME writes those itself if you have instructed it to write any other ID3 tags, so if you leave the tagging to foobar2000, they should not be added.
http://hydrogenaudio.org/forums/?showtopic=101861
  • b0nk
Fortunately lame is open source and I can avoid it adding those 2 tags by commenting some methods in the code and compile my own.
As for track/tracktotal I thought it was an optional thing in fb2k. It's a good thing it is that way.
Thanks again!
  • db1989
  • Global Moderator
Of course, and I thought of suggesting that, but then I assumed it would be simpler to have foobar2000 do the tagging. Is there any particular reason that you prefer to have LAME handle it?
Anyway, glad you’re happy with the available options.
  • b0nk
Yes it is simpler to have foobar2000 do the tagging and it's how I usually do. I just like to mess around with tools and see what I can do with them even if it's something small. Like you said I am happy with the options I'm given and I try most of them for fun and knowledge.
  • db1989
  • Global Moderator
I like this attitude…and wish it were more common.  I’m similar. I often find it fun to research and/or work out things for myself, so I’m not sure why this approach is so rare comparatively.
