Topic: help me interpret this CUETools accurip output? (Read 2302 times) previous topic - next topic
  • boombass
I am tidying up some old CD rips to satisfy my OCD, and I have found CUETools to be an amazingly helpful tool. In almost all cases it has convinced me that my old old rips are still accurate even thought they were done before there was AccurateRip data to compare them to.
But one CD (actually a two CD set) has given me this output:
[CUETools log; Date: 7/8/2013 11:09:24 AM; Version: 2.1.5]
CD-Extra data track length 02:39:49.
[CTDB TOCID: 2uMDQvilwo_ZFRxvcwEvnM1Ibvw-] found.
Track | CTDB Status
  1  | (  2/120) Accurately ripped
  2  | (  1/120) Differs in 36 samples @02:53:32, or (1/120) differs in 36 samples @02:53:32
  3  | (  2/120) Accurately ripped
  4  | (  1/120) Differs in 31 samples @00:59:21-00:59:22,01:41:22, or (1/120) differs in 96 samples @00:59:21-00:59:22,01:29:32,01:41:22
  5  | (  1/120) Differs in 1 samples @01:04:59, or (1/120) differs in 9 samples @01:04:59,02:40:50
  6  | (  1/120) Accurately ripped, or (1/120) differs in 74 samples @04:41:00
  7  | (  2/120) Accurately ripped
  8  | (  1/120) Differs in 109 samples @00:53:20,01:11:09-01:11:10, or (1/120) differs in 109 samples @00:53:20,01:11:09-01:11:10
  9  | (  1/120) Accurately ripped, or (1/120) differs in 473 samples @00:46:67,01:16:67,01:29:01,01:47:02,02:29:02,02:47:02,02:52:67,03:04:67,03:05:02,03:11:01-03:11:02,03:41:02,03:52:66-03:52:67
 10  | (  1/120) Accurately ripped, or (1/120) differs in 115 samples @00:11:20-00:11:21,00:23:19-00:23:20,02:05:09,02:35:19
[AccurateRip ID: 0010ca38-0085b529-810afa0b] found.
Track  [  CRC  |  V2  ] Status
 01    [e5b7fa9e|1d05b010] (00+00/75) No match
 02    [b2d3e84a|05725b44] (00+00/77) No match
 03    [9c6aee92|ad8e521d] (00+00/77) No match
 04    [5d7ffba7|ed4a87ab] (00+00/76) No match
 05    [f7cfe9fc|5856388d] (00+00/77) No match
 06    [cb4dd4ef|c6bdc801] (00+00/74) No match
 07    [f151ef31|7cfdbdae] (00+00/75) No match
 08    [98f1660c|7f61b098] (00+00/75) No match
 09    [5bb444fe|6b245446] (00+00/74) No match
 10    [2af32be6|60a4e069] (00+00/71) No match
Track Peak [ CRC32  ] [W/O NULL] [  LOG  ]
 --  99.1 [A12DE607] [A8E54C6F]
 01  95.9 [5D889C77] [5DA6F2D9]  CRC32
 02  96.1 [73240C40] [70AD0F70]  CRC32
 03  98.2 [5E9316E1] [13310584]  CRC32
 04  99.1 [CB8C0ADD] [796AE867]  CRC32
 05  98.1 [6B192635] [28B2E837]  CRC32
 06  99.0 [6FED9C7C] [6DF24B63]  CRC32
 07  92.9 [1C58F380] [FF3CE9DC]  CRC32
 08  98.0 [E9CAFDA1] [4DE1C6C0]  CRC32
 09  94.5 [1A41D3CF] [108EA16C]  CRC32
 10  91.1 [E3E3ECBA] [87C9FAED]  CRC32
How should I take this? Is my rip accurate, or not? Why the different samples? Can I assume they are from someone else's rip?
  • korth
No errors in the rip? (I see that all the track CRCs match the original rip but a rip log would have been helpful).
You do not have an accurate match in either database for the complete disc.
The sample differences are a comparison of your rip against others in the CUETools Database (CTDB) that have a recovery record (the disc may be repairable), however (1/x) records should be considered unreliable for repair use (see known issues).
You may have a disc version that just isn't in either database.
korth
  • boombass
No, no errors in the rip. Here is the log:
EAC extraction logfile from 10. August 2008, 10:01 for CD
David Bowie / Aladdin Sane
Used drive  : LITE-ON DVDRW LH-20A1P  Adapter: 0  ID: 0
Read mode  : Secure with NO C2, accurate stream, disable cache
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Used output format : E:\_music encoding\_programs\flacattack\flacattack.exe  (User Defined Encoder)
                     128 kBit/s
                     Additional command line options : "E:\_music encoding\_programs\flacattack\flacattack.ini" %s "%a" "%t" "%g" "%y" "%n" "%m" %o
Other options      :
   Delete leading and trailing silent blocks : No
   Native Win32 interface for Win NT & 2000
Track  1
     Filename E:\_encode temp\01 - David Bowie - Watch That Man.wav
     Peak level 95.9 %
     Track quality 100.0 %
     Test CRC 5D889C77
     Copy CRC 5D889C77
     Copy OK
Track  2
     Filename E:\_encode temp\02 - David Bowie - Aladdin Sane (1913-1938-197 ).wav
     Peak level 96.1 %
     Track quality 99.9 %
     Test CRC 73240C40
     Copy CRC 73240C40
     Copy OK
Track  3
     Filename E:\_encode temp\03 - David Bowie - Drive-In Saturday.wav
     Peak level 98.2 %
     Test CRC 5E9316E1
     Copy CRC 5E9316E1
     Copy OK
Track  4
     Filename E:\_encode temp\04 - David Bowie - Panic in Detroit.wav
     Peak level 99.1 %
     Test CRC CB8C0ADD
     Copy CRC CB8C0ADD
     Copy OK
Track  5
     Filename E:\_encode temp\05 - David Bowie - Cracked Actor.wav
     Peak level 98.1 %
     Test CRC 6B192635
     Copy CRC 6B192635
     Copy OK
Track  6
     Filename E:\_encode temp\06 - David Bowie - Time.wav
     Peak level 99.0 %
     Test CRC 6FED9C7C
     Copy CRC 6FED9C7C
     Copy OK
Track  7
     Filename E:\_encode temp\07 - David Bowie - The Prettiest Star.wav
     Peak level 92.9 %
     Test CRC 1C58F380
     Copy CRC 1C58F380
     Copy OK
Track  8
     Filename E:\_encode temp\08 - David Bowie - Let's Spend the Night Together.wav
     Peak level 98.0 %
     Track quality 99.7 %
     Test CRC 4EC18409
     Copy CRC E9CAFDA1
     Copy OK
Track  9
     Filename E:\_encode temp\09 - David Bowie - The Jean Genie.wav
     Peak level 94.5 %
     Test CRC 1A41D3CF
     Copy CRC 1A41D3CF
     Copy OK
Track 10
     Filename E:\_encode temp\10 - David Bowie - Lady Grinning Soul.wav
     Peak level 91.1 %
     Test CRC E3E3ECBA
     Copy CRC E3E3ECBA
     Copy OK
No errors occured
End of status report
So maybe just a different pressing? If the EAC rip had no errors, I can pretty much be sure I had a good rip, I think.
  • korth
Well track 8 could be iffy.
Test CRC 4EC18409
Copy CRC E9CAFDA1
But there's no clear indication that the Copy CRC is wrong and secure mode did not correctly copy the track.
korth
  • gib
Re-rip your disc and any questions will most likely be answered.
  • greynol
  • Global Moderator
Test CRC 4EC18409
Copy CRC E9CAFDA1
You could say the same thing about the test pass.
So that it is clear matching CRCs are proof of consistent data; they are not proof of an accurate extraction. If the test pass finished without EAC exhausting all the allotted re-read sets, what would that tell you?
  • Last Edit: 13 July, 2013, 12:11:03 AM by greynol
  • greynol
  • Global Moderator
With the same drive, program and settings?
Maybe if you changed at least one of those things up then the word "likely" would be more easily entertained.
  • korth
Test CRC 4EC18409
Copy CRC E9CAFDA1
I did call the track iffy. Using only the log, there's information missing for the test pass. If any uncorrectable read errors did occur during the test pass they aren't reported to the log as suspicious positions. The copy pass however didn't report any uncorrectable read errors to the log as suspicious positions but had a track quality of less than 100%. So re-reads occurred and at least 8 reads had the same CRC. Could that CRC be wrong? Yes it happens occasionally. AccurateRip or CTDB data would be helpful.
I can't tell that's what happened from the log but I do agree that rarely it can. If the on-screen rip dialog showed the test pass completed (with re-reads) but without any uncorrectable read errors then at least 8 reads had the same CRC for that pass as well but with a different CRC than the copy pass. If I had this additional information I would be even more likely to question the copy result.
Either way I would have cleaned the disc and re-ripped the track. If I still didn't find the result satisfactory I would try a different drive or settings as you suggested.
korth
  • greynol
  • Global Moderator
When someone has gone though an entire collection in order to focus on the questionable rips, "rare" all of a sudden becomes less so.
Uncorrectable read errors?  Call it what it really is: data that isn't consistent beyond an arbitrarily chosen threshold. The two concepts are not at all the same.
  • Last Edit: 13 July, 2013, 01:36:09 AM by greynol
  • gib
You're correct, of course.  Diversity is a good thing when ripping.
When I saw boombass' original rip is 5 years old I assumed they no longer have the same optical drive, thus the suggestion in my first post in all its brevity.  I really shouldn't make such an assumption.
So to expound, I'd suggest boombass re-rip the disc on a totally different drive.  Not another of the same model, or similar model, or another brand that OEMed the same internal guts and slapped their name on it.  A totally different drive.  That's the first step.
