Topic: [DOUBLE POST] Help me understand some of the tagging functions! (Read 601 times) previous topic - next topic
Rewrite File Tags; Reload info from files
So in what instance would one use these options?  When I modify the tags using foobar, does it not automatically update the files?  Similarly, if I edit tags using another app, does it not automatically update in foobar?
Much appreciated.
  • Last Edit: 01 July, 2013, 09:27:49 PM by shortdude123
  • db1989
  • Global Moderator
Was something wrong with my answer to your first round of these questions?
But to elaborate for posterity:
It does. The option to rewrite is for when you have changed the tagging scheme, as I said beforeā€”or, perhaps, when you have some other reason to want to delete the existing tag(s) and rebuild it/them.
The question is too vague. Update where? Normal playlists do not update automatically. The option to reload metadata is ideal for this purpose, as I said before. And to add: the Media Library should notice changes to metadata of files that it is monitoring/indexing and reflect these (if it is set to display that information), and, intuitively, autoplaylists should update automatically too.
