Topic: How to tell if HDCD component is operating? (Read 1368 times) previous topic - next topic
  • rbbert
I have a couple of questions (actually way more than that, but...)
Where is the "status window" and how do I affect what it shows?
How can I tell whether an installed component (e.g. HDCD) is operating at any given time?
TIA
  • dhromed
DSP components are active when they're in the left list of the DSP Preferences page. File format components are siltently active when you're playing a relevant file. Obviously the mp3 decoder is not active for a FLAC file.
Status window? Do you mean the status bar (at the bottom), or the output console? (Menu: View > console)
  • rbbert
Thank you.
I've installed the HDCD component.  Where can I see its activity when playing an HDCD file?  BTW, HDCD doesn't show up in the right window (to be available for move to the left window); should it, and if so how?
  • Porcus
It is the %__hdcd_info%. At least if you use the default user interface: Preferences --> Display --> Default user interface.
Put the code at the end of one of the Playback state display formatting codes, and it will show if a HDCD is playing at the approriate place (top/bottom/tip) and a question mark otherwise.  Using [blockquote][ |'('%__hdcd_info%')']  [/blockquote] the parentheses are literal and will show, but the brackets mean that it will be omitted if not present.
  • Last Edit: 17 June, 2013, 12:36:47 PM by Porcus
