Topic: Lost MP3 Option in EAC? (Read 2684 times) previous topic - next topic
  • JZM
Last time I opened EAC, it asked me if I wanted to use some kind of online lookup tool (don;t recall name) for track info, and I said Yes. Big Mistake. Now the MP3 and FLAC options have vanished. I have made no other changes to program or program directories. My only options now are WAV, CMP, IMG, WRI--and the damned thing cannot find the tracks online. I don't know if this new lookup thingie has killed LAME, or caused some other issue, but would prefer to fix rather than reinstall and lose all settings.
Any help appreciated, thanks!
  • greynol
  • Global Moderator
There is no connection between having EAC get track information from the web and mp3 creation.
What has changed is that you have installed a newer version with where that MP3 button has now been renamed to CMP. This button still performs the exact same function which is to output to a compressed format.  The reason for the change is that not everyone compresses using mp3 and the portion who don't could have only gone down since the days when that button wore a different label.
  • Last Edit: 31 May, 2013, 02:34:25 PM by greynol
  • JZM
Thanks, I'll try that out!
So...which one is FLAC?
  • greynol
  • Global Moderator
FLAC is also a compressed format, so you use the same button. If you want to rip to different compressed formats without having to reconfigure them, use the profile function.
  • greynol
  • Global Moderator
In light of the recent double-post, I thought I'd bump this since the OP still seems to be in need of assistance.
  • Last Edit: 18 June, 2013, 06:06:34 PM by greynol
