Topic: [TOS #8] From: Directsound vs WASAPI vs ASIO (Read 1382 times) previous topic - next topic
After reading many of the posts on this forum, it appears that there is no evidence that ASIO or WASAPI sounds any better than Directsound on Windows 7. I understand the importance of ABX testing - and I am interested in a way to do a double blind test of such claims. Let me first of all state that I cannot hear any difference. For me to be objective, I have used the same player for all tests - foobar2000 - and simply changed the Output from Directsound to WASAPI to ASIO. However, to do this, I have to stop the playback, change the driver, and then restart playback. This means comparions are doubtful at best due to the delay involved and my knowledge of what driver I selected.
How have others conducted such tests? Please note I am not trying to prove a difference exists - just to find a way to do the test properly. The ABX plugin for foobar2000 has been very useful to compare different WAV files. Obviously, one cannot use it for this sort of experiment.
Thank you for any suggestions or pointers to where this has been proved one way or another.
On my system - I can tell the difference easily esp on low frequencies; I have an USB-> Spdif sound card to m-Audio DSM3 speakers
  • db1989
  • Global Moderator
Strike two.
In case you are still oblivious, read #8 of the Terms of Service, to which you assented during your registration. Posts such as this and your previous one, whose deletion to the Recycle Bin should have served as a hint, are blatantly in violation thereof and thus are not welcome.
  • Last Edit: 23 May, 2013, 03:14:56 PM by db1989
