Topic: Guide for how to set up CUETools (Read 4153 times) previous topic - next topic
What are the best settings for CUETools to extract flac files into multiple tracks?
  • tpijag
Granted i have sparse knowledge of the program, though documentation seems to be thorough. is there something you are looking for beyond selecting Action  = encode, Mode = Tracks ?
in the chance you are not aware of these sources, here you go.
the docs that i am aware of are located: Wiki
There is also a dedicated thread here Thread
  • Last Edit: 19 May, 2013, 10:13:16 PM by tpijag
  • Porcus
The thread has been around for four years and a half, and at least lots of the early information is obsolete. A guide would be A Good Thing (but someone then has to make it).
  • korth
The best settings to accomplish what result? I can think of a few possible scenarios.
The OP probably should leave advanced settings at default for now. For the GUI settings I suggest staring with:
  • Input: Folder browser (select the CUE or the Image if it has an embedded CUE)
  • Output: Use template
  • Template: select one (maybe start with [%directoryname%\]new[%unique%]\%filename%.cue)
  • Action: Encode (default)
  • Mode: Tracks (leave checkboxes alone)
  • Audio Output: Lossless;
    • Flac
    • libFlac (reason)
    • select 5-8
click GO
As far as a Guide for how to set up CUETools, I am currently in the process of collecting screen captures to write something for the wiki. The first guides will be very basic as above (maybe a few more details) and include:
  • rip with CUERipper
  • verify, repair, and split image with CUETools
With suggestions and help, it can be expanded from there to cover other scenarios.
korth
So default settings is fine?
  • db1989
  • Global Moderator
Unless the program is badly designed, that is always a safe bet. CUETools is not badly designed.
You still have not specified what you mean by “best settings”. For what? Perhaps if you provide an example of what you imagine non-“best” settings would do that you find undesirable, we can tell you whether such concerns are at all justified. If you are concerned about quality, for instance, do not assume that a well-developed program like CUETools needs to be persuaded to pass audio without adulteration. It will preserve the quality of lossless input by default, as any sane program would.
    • Flac
    • libFlac (reason)
    • select 5-8
click GO
I said it in the first post
