Topic: WAV tagging creates 2nd id3 chunk (Read 4001 times) previous topic - next topic
WAV tagging in foobar2000 (1.2.6) creates a second "id3" chunk.
Wavelab 8, after loading the .wav file without any tags, and added the value "ABB" to TPE1:
00000000h: 52 49 46 46 AA F0 21 02 57 41 56 45 4A 55 4E 4B; RIFFªð!.WAVEJUNK
00000010h: 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ................
00000020h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ................
00000030h: 66 6D 74 20 10 00 00 00 01 00 02 00 44 AC 00 00; fmt ........D¬..
00000040h: 10 B1 02 00 04 00 10 00 69 64 33 20 1A 00 00 00; .±......id3 ....
00000050h: 49 44 33 03 00 00 00 00 00 0F 54 50 45 31 00 00; ID3.......TPE1..
00000060h: 00 05 00 00 00 41 42 42 00 00 64 61 74 61 40 F0; .....ABB..data@ð
00000070h: 21 02 00 00 00 00 00 00 02 00 02 00 00 00 FD FF; !.............ýÿ
00000080h: FE FF FE FF FF FF FF FF 02 00 FC FF FF FF 01 00; þÿþÿÿÿÿÿ..üÿÿÿ..
Wavelab8 stores the ID3 chunk at the beginning, not at the end of the file.
Then I loaded the track into foobar2000 (1.2.6) and updated TPE1 with "ABBA":
00000000h: 52 49 46 46 D4 F0 21 02 57 41 56 45 4C 49 53 54; RIFFÔð!.WAVELIST
00000010h: 12 00 00 00 49 4E 46 4F 49 41 52 54 05 00 00 00; ....INFOIART....
00000020h: 41 42 42 41 00 00 4A 55 4E 4B 02 00 00 00 00 00; ABBA..JUNK......
00000040h: 10 B1 02 00 04 00 10 00 4A 55 4E 4B 1A 00 00 00; .±......JUNK....
00000090h: 00 00 00 00 02 00 FF FF 00 00 FE FF 00 00 00 00; ......ÿÿ..þÿ....
The "id3" chunk TPE1 is unchanged, but foobar2000 has created a 2nd "id3" chunk at the end of the file:
0221f0b0h: FF FF 69 64 33 20 22 00 00 00 49 44 33 03 00 00; ÿÿid3 "...ID3...
0221f0c0h: 00 00 00 17 54 50 45 31 00 00 00 0D 00 00 01 FF; ....TPE1.......ÿ
0221f0d0h: FE 41 00 42 00 42 00 41 00 00 00 00            ; þA.B.B.A....
which is a bug.
After that I re-opened the track in Wavelab 8 and updated TPE1 with "AB" (btw. the old value shown was "ABBA" - maybe overwritten during the loading from the second "id3" chunk).
00000000h: 52 49 46 46 C2 F0 21 02 57 41 56 45 4A 55 4E 4B; RIFFÂð!.WAVEJUNK
00000040h: 10 B1 02 00 04 00 10 00 69 64 33 20 18 00 00 00; .±......id3 ....
00000050h: 49 44 33 03 00 00 00 00 00 0E 54 50 45 31 00 00; ID3.......TPE1..
00000060h: 00 04 00 00 00 41 42 00 64 61 74 61 40 F0 21 02; .....AB.data@ð!.
00000070h: 00 00 00 00 00 00 02 00 02 00 00 00 FD FF FE FF; ............ýÿþÿ
Wavelab 8 has removed the second "id3" chunk (correctly).
Please fix it for 1.2.7 - THANKS.
Ooops ... sorry .. all correct - just saw that the chunk name is JUNK created by foobar2000 ... sorry - too late.
