importing XML foo_playcount?
Reply #4 – 2013-05-13 20:26:27
I'm completely new to this kind of thing and know nothing about XML I suggested to open the file with a text editor just to make sure that it contains more than a few data records so that it can be assumed it comprises your entire library; foobar does not urge you to know anything about the XML format . Would you mind posting a list of your components as it is described here [See: "5. Post other helpful information."]? Additionally it would be useful to tell us the title formatting scripts from your columns which aren't updated and what user interface and playlist viewer you are using. I still have some difficulties to understand exactly what has happened on your computer: Did your failed HDD contain only your audio files, you replaced it and an untouched foobar2000 configuration, located on another and intact HDD, is suddenly no longer able to show the stats correctly? Or was your foobar2000 installation affected as well and you had to build up from scratch besides the exported Playback Statistics? First, sorry for very late reply. I got pretty busy lately. I very much appreciate you taking the time to help me. The XML seems like it's fine, it has what appears to be thousands of entries, like it should. Basically, the first.My music was stored on my C drive (that died) while I had portable version of Foobar installed on D drive. I had a backup of my music files on F drive. Due to a past experience, I decided to put one folder in first and when I did all the data on those files reset on Foobar. I was messing around with some things a few days before it crashed though and had created an XML that was saved to my D drive. (I only used my C drive for music because that's where my playlists recognized them for the past decade, and my harddrive was slowly running out of room, literally everything else besides System files are on D and F). So in other words, If I were to transfer my music back to the C Drive it overwrites all the playback data that Foobar saved back several months to when the files were last used, and the only way I see to fix this is by using the XML I had created. Some things I thought would affect don't seem to be the case. I made 100% sure on my test folder/album that the file paths are exactly the same as what they were when the XML was created, the file names in every field are exactly the same except for the Playback Stats but the XML still doesn't seem to do anything.Core (2013-03-29 11:10:54 UTC) foobar2000 core 1.2.4 foo_albumlist.dll (2013-02-11 11:28:58 UTC) Album List 4.5 foo_audioscrobbler.dll (2008-05-13 20:36:16 UTC) Audioscrobbler 2.3.1 foo_cdda.dll (2013-03-07 09:48:32 UTC) CD Audio Decoder 3.0 foo_converter.dll (2013-03-29 11:09:02 UTC) Converter 1.5 foo_customdb.dll (2013-04-18 21:58:10 UTC) Custom Database 0.1.0_beta1 foo_dop.dll (2008-09-28 20:00:59 UTC) iPod manager 0.6.3.0 foo_dsp_eq.dll (2013-02-11 11:28:58 UTC) Equalizer 1.0 foo_dsp_std.dll (2013-02-11 11:28:50 UTC) Standard DSP Array 1.2 foo_freedb2.dll (2013-02-11 11:27:56 UTC) Online Tagger 0.7 foo_httpcontrol.dll (2012-08-14 19:19:51 UTC) HTTP Control 0.97.12 foo_input_std.dll (2013-03-29 11:09:54 UTC) Standard Input Array 1.0 foo_input_tta.dll (2009-10-08 03:58:35 UTC) TTA Audio Decoder (unofficial) 2.4.2 foo_jesus.dll (2010-10-12 18:58:15 UTC) Autosave & Autobackup 10 foo_lyricsgrabber2.dll (2011-04-27 15:09:25 UTC) Lyrics Grabber 2 0.5.5.2 beta foo_osd.dll (2013-04-19 06:28:30 UTC) On-Screen Display 1.73 foo_playcount.dll (2011-07-20 15:40:49 UTC) Playback Statistics 3.0.2 foo_playlisthistory.dll (2011-06-06 14:50:21 UTC) Playlist History 0.1.6 foo_queuecontents.dll (2012-04-03 19:40:38 UTC) Queue Contents Editor 0.5.1 foo_rgscan.dll (2013-03-29 11:09:02 UTC) ReplayGain Scanner 2.2 foo_softplaylists.dll (2013-04-18 20:49:45 UTC) Soft Playlists 2011-02-05 foo_textdisplay.dll (2012-08-06 05:12:02 UTC) Text Display UI Element 1.1 beta 1 foo_texttools.dll (2011-05-05 17:21:05 UTC) Text Tools 1.0.5 foo_ui_columns.dll (2011-02-27 20:22:58 UTC) Columns UI 0.3.8.8 foo_ui_std.dll (2013-03-29 11:09:24 UTC) Default User Interface 0.9.5 foo_uie_lyrics2.dll (2011-04-28 17:45:42 UTC) Lyric Show Panel 2 0.4.6.15 foo_uie_wsh_panel_mod.dll (2013-04-18 20:57:58 UTC) WSH Panel Mod 1.5.6 foo_unpack.dll (2013-02-11 11:28:10 UTC) ZIP/GZIP/RAR Reader 1.6 foo_winamp_ipc.dll (2008-04-21 09:58:08 UTC) Winamp IPC emulator 0.1.3 I'm sure there are a few of those I don't really need anymore, I just never bothered to go through which ones I actually use often.
