Topic: [TOS #8] From: What kind of turntable should I get (Read 599 times) previous topic - next topic
  • dpastern
I think you would be rather hard pressed to get "comparable performance" from vinyl, at least if we are talking about conventional attributes such as distortion and signal-to-noise ratio / dynamic range.
There's more to music than measurements.  SETs (single ended triode valve amps) measure worse than your typical Class AB transistor amp, but musically, blow them away.  That's my experience.  Or course, making a good SET isn't easy.
Dave
