Topic: Changing Tags on Currently Playing Song (Read 857 times) previous topic - next topic
  • BASGTA
So I started to notice that after I formatted and installed everything about a month or two ago, that whenever I play a song in Foobar the the %data% coloumn will change from "2004" to "2004-00" or even the exact date "2004-02-26"  It annoyed me but I didn't really pay any attention to it.  I'm noticing that on some tracks however it'll erase all the tags, example...
Here I'm listening to Ramp - Enjoy the Music (El Grekoz Remix)
Here I'm listening to Ramp - Enjoy the Music (Original Mix)
Once I stop the playback or switch songs the tags come back.
I'm thinking there's something in the options that I haven't found yet that is enabling this.  I have version v1.2.3
  • marc2003
foobar itself will never touch your files unless you explicitly tell it to. if they really have been changed, it will be some other component. right click the tracks(s)>properties and then the properties tab and look at Last modified. were the tags really changed or is it a playlist display bug?
also, it looks like you're using columns UI because default UI doesn't show the elapsed time. posting a full component list might help.
  • BASGTA
I didn't mean it permanently changed the tags, but it only appears that it has changed as it goes back to normal when playback is stopped.
I just noticed that when I'm listening to that song, when I fast forward the normal tags pop up for a split second.
Core (2013-02-13 11:26:10 UTC)
    foobar2000 core 1.2.3
foo_albumlist.dll (2013-02-13 11:24:52 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2009-08-21 02:15:56 UTC)
    Audioscrobbler 1.4.2
foo_cdda.dll (2013-02-13 11:24:22 UTC)
    CD Audio Decoder 3.0
foo_chain_impexp.dll (2011-02-20 19:27:02 UTC)
    DSP chain [de]serializer 1.0
foo_channel_mixer.dll (2008-03-12 09:37:47 UTC)
    Channel Mixer 0.9.6.5
foo_comserver2.dll (2006-07-31 19:13:20 UTC)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2013-02-13 11:24:22 UTC)
    Converter 1.5
foo_discogs.dll (2011-08-12 07:42:42 UTC)
    Discogs Tagger 1.30
foo_dop.dll (2010-06-25 21:59:12 UTC)
    iPod manager 0.6.8.1
foo_dsp_crossfeed.dll (2010-08-28 19:48:42 UTC)
    Crossfeed 1.1.1
foo_dsp_delta.dll (2008-10-24 20:57:16 UTC)
    Noise Sharpening DSP 1.0.0
foo_dsp_dolbyhp.dll (2010-01-22 20:40:28 UTC)
    Dolby Headphone Wrapper 1.4.1
foo_dsp_eq.dll (2013-02-13 11:24:54 UTC)
    Equalizer 1.0
foo_dsp_fsurround_beta.dll (2010-12-04 21:50:50 UTC)
    FreeSurround 0.8.1
foo_dsp_mm.dll (2008-06-06 05:29:10 UTC)
    Matrix Mixer 0.3
foo_dsp_std.dll (2013-02-13 11:24:44 UTC)
    Standard DSP Array 1.2
foo_dsp_xgeq.dll (2011-05-25 04:28:24 UTC)
    Graphic Equalizer 0.1.2
foo_fileops.dll (2013-02-13 11:23:12 UTC)
    File Operations 2.2
foo_input_dts.dll (2010-09-03 16:18:04 UTC)
    DTS decoder 0.3.0
foo_input_std.dll (2013-02-13 11:23:54 UTC)
    Standard Input Array 1.0
foo_jesus.dll (2010-09-23 06:34:06 UTC)
    Autosave & Autobackup 10
foo_osd.dll (2011-02-09 07:45:16 UTC)
    On-Screen Display 1.69
foo_rgscan.dll (2013-02-13 11:24:30 UTC)
    ReplayGain Scanner 2.1.2
foo_run.dll (2009-06-07 22:15:18 UTC)
    Run services 0.3.7
foo_softplaylists.dll (2011-02-05 08:04:50 UTC)
    Soft Playlists 2011-02-05
foo_ui_columns.dll (2010-03-06 16:54:31 UTC)
    Columns UI 0.3.8.4
foo_ui_std.dll (2013-02-13 11:23:58 UTC)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 04:22:24 UTC)
    Album Art Panel 0.2.7.1
foo_uie_panel_splitter.dll (2009-11-26 05:03:32 UTC)
    Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_playlists_dropdown.dll (2009-09-24 04:44:46 UTC)
    Playlists Dropdown 0.7.6
foo_uie_vis_channel_spectrum.dll (2008-05-18 07:02:12 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2008-04-20 00:18:50 UTC)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_vis_shpeck.dll (2013-03-17 21:53:56 UTC)
    Shpeck - Winamp vis plugins wrapper 0.3.7
foo_vst.dll (2011-03-05 13:19:04 UTC)
    VST 2.4 adapter 0.9.0.3
foo_wave_seekbar.dll (2011-10-18 05:17:06 UTC)
    Waveform seekbar 0.2.14
  • db1989
  • Global Moderator
Given the presence of said component in your list, are we to assume Marc was correct?
I'm noticing that on some tracks […]
Which tracks? What format(s)? Do they share any traits that might be contributing to the observed behaviour?
Please be more specific when reporting problems.
  • BASGTA
I've only noticed it on mp3s.  I'm thinking that some of my mp3s have ID3v1 and ID3v2 filled out, and when I play the mp3 it switches from one type to the other.  Going with the example in my first post, when I open the properties of Ramp - Enjoy The Music the tags will be displayed normally (whether I'm listening to it or not) if I copy and paste each metadata field then paste it on to itself, the problem is fixed for this one file.
It's like I'm editing a field that I can't see.  Which is what lead me to believe there must be an option somewhere.
  • Last Edit: 06 April, 2013, 12:50:44 PM by BASGTA
