Topic: High CPU usage after playing stops (50%) (Read 503 times) previous topic - next topic
  • zooliat
Hi guys, i have this weird problem, very high CPU usage (>50%), even after playing stops.
Foobar 1.2.3 portable with the default interface, no DSP activated.
Components installed: Asio support, Monkey audio decoder, WASAPI output support (currently playing through) and Waveform seek bar (downmix to mono, directx9).
@Playlist view:
Custom columns
Name/Title - %artist% - %title% - left
Custom grouping schemes
Folders - $directory(%path%,2)\%directoryname%
Folder - %directoryname%
I had the same configuration for a while, but it started recently (i guess after i updated to 1.2.4 so i reinstalled portable version of 1.2.3 and copied all the settings manually). Any ideea what's happening?
Later edit: it's foo_wave_seekbar.dll (0.2.30.1, because 0.2.33 randomly doesnt display the waveform) that's causing the problem.
  • Last Edit: 02 April, 2013, 08:58:35 AM by zooliat
  • db1989
  • Global Moderator
Closed due to repost in the relevant thread.
