Topic: AIFF to FLAC: How much quality would I lose, if any ? (Read 4791 times) previous topic - next topic
  • Aldem
I have some AIFF files, but I use FLAC as a standard normally, so i was wondering what the results of a conversion from AIFF to FLAC would be.
A disaster ? No differences ? A small loss ?
Alan
  • julf
No impact on the actual audio (both formats are lossless), but mapping of metadata / tags depends on what conversion program you use.
  • db1989
  • Global Moderator
What did you think the word lossless stands for?
  • Porcus
If the signal is one of the usual end-user delivery formats, yes (44.1 or 48 or multiples, 16 or 20 or 24 ...).
But the AIFF-C format (same file suffix) supports signals which FLAC does not, as far as I know.
  • Aldem
I know that, but I was also wondering some less evident stuff like Porcus mentionned.
  • greynol
  • Global Moderator
Why not take the initiative and test them with foobar2000's bit comparator rather than rely on speculative discussion?
  • Aldem
Because I didn't know such a thing existed. I will look into it, thank you.
  • greynol
  • Global Moderator
  • Last Edit: 01 April, 2013, 04:22:44 PM by greynol
