Topic: A few songs in my library that play silence. (Read 774 times) previous topic - next topic
  • intusvox
Hello,
I have two songs in my library that are silent when I play them, (the playback bar moves, but there is no sound) everything else is fine.
I have successfully played these songs without problems on Audacity.
I have tried both the portable and full installation of Foobar2000.
I'm not sure if this will help in any way, but I noticed these two were the only songs in my library that have <ENCODED> by MediaMonkey 3.2.0 in the PROPERTIES.
Prior to reformatting my computer, these songs worked fine on Foobar2000. Perhaps somethings wrong with the new Foobar2000?
  • nastea
Are these flac files?
If so, decoding them and encode to flac again with proper tag settings might solve the problem.
  • intusvox
Yes these were flac files, sorry for not mentioning earlier.
I've found the problem!
After further tampering with the settings, I found that setting Source mode and Processing to none (in ReplayGain) fixes the problem.
Can someone explain why this is?
  • tedsmith
Just a guess, but it sounds like the Replay Gain tags are messed up and enabling Replay Gain causes the volume to be very low.
