Topic: Can I "work" on my PC while ripping CD collection to FLAC wi (Read 2867 times) previous topic - next topic
  • prskier17
I have decided to rip 200+ CD's to FLAC since I finally have my home sound system networked to a home PC.  My plan is to bring CD's to work and rip while I'm at my desk.  I'm using EAC and have setup per these instructions: LINK REMOVED
My questions is based on the setting linked can I work as normal on my PC without glitches in the Rip? I've complete about a half dozen CD's without any errors in the log.
Chris
  • Last Edit: 19 August, 2013, 12:18:52 PM by greynol
  • probedb
Yes you can  Assuming you don't have an antiquated system that dates from the 18th century
I think the whole "don't touch your pc while it's doing something important" is a relic from singlecore/low RAM times. Like, remember burning CDs and praying to not get any buffer underruns cause your PC ran out of RAM and the HDD wasn't fast enough?
I had the "pleasure" of being stuck on a 10yo machine for a week, and it was... bad. Could barely do anything without system starting to slowdown and stall. I'm just glad that it's a thing of the past.
  • prskier17
Haha.... yes I remember holding my breath while hoping to successfully burn a CD!  Thanks for the responses... I just wanted to make sure that I wasn't going to be investing this time and then having to do it all over again!
  • probedb
The advantage of secure ripping is that it will tell you if there's anything wrong anyways
  • jkauff
  • Members (Donating)
If you're doing a lot of CDs, you might want to consider using dbPoweramp CD Ripper. Rips are just as accurate as EAC, and it will use all the cores on your CPU so it's much faster. You can still do other work while it's ripping, but it's so fast you probably won't have time--you'll be busy changing CDs.
  • skamp
  • Developer
Actually EAC will launch FLAC processes in the background too. dBpoweramp's advantage is that it will burst rip tracks, check them against the AccurateRip database, and only rip them in "secure" mode when needed. Ripping a CD in good condition only takes 5 minutes. Whereas EAC can only rip all tracks either in burst rip mode or in secure mode. You can choose the former and manually re-rip tracks in secure mode when needed, but that takes user involvement, where dBpoweramp is fully automated.
  • Last Edit: 26 March, 2013, 11:09:56 AM by skamp
  • greynol
  • Global Moderator
I'm able to rip at burst speeds with EAC and be confident that it will automatically perform re-reads when errors are detected. It depends on the drive, though I'm not so sure that there are that many that can give this type of performance/reliability.  Mine is a Plextor PX716 which provides reliable error information and can be configured as non-caching when EAC uses FUA.
  • prskier17
That's what I was hoping... thanks!
