Topic: Foobar 1.2.4 b3 slows down on short OGGs. (Read 637 times) previous topic - next topic
I've been working on quite a lot of sound effects, and when listening to them in Foobar, Foobar immediately becomes unresponsive and has to be closed and restarted.
Note: This only happens when they are set to loop.
  • Last Edit: 26 March, 2013, 12:36:53 AM by BrokenHaiku
  • Case
  • Developer (Donating)
Program getting slow is not the same as the program crashing. Last time someone complained about foobar getting slow doing what you just described the cause was his 3rd party visualizations components.
  • Zao
Does it still happen in a fresh, portable, install? Can you post a components listing?
